Advice for Stalling/Idle Problems on 20v - 7A Motor
Thought I would just give a heads up. I was experiencing some idle/stalling problems, especially when engaging the clutch and coming to a stop. Often the engine would start to idle at about 800 rpms before slowing dropping then stalling.
I replaced the o-ring on the throttle valve air bypass adjustment screw and the problem went away. Now if I could just fix my warm start issue.
what worked for me...
<center><img src="http://img.alibaba.com/photo/50584543/Sell_Crankshaft_Position_Sensor.jpg"></center><p>see post here...<ul><li><a href="https://forums.audiworld.com/9080/msgs/419279.phtml">Good-bye to hot start issue on the CQ...</a></li></ul>
