Advise on oil pan gasket on 95' 90.
Got any tips with the gasket replacement on the oil pan. Do you use any sealant or put it on dry? How about the actual gasket, should I stick with a dealer part? Torque requirements? Any responce is greatly appreiated. Thanks.
Re: oil pan gasket on 95' 90.
Any DIY maintenance should be accompanied with some sort of referance material! Namely the Bentley Manual, if for nothing else torque spec's!
Use only the OEM gaskets! ;O)
They can be had from "other than dealership sources", to save some cash!
No extra sealents required.
Torque spec's can be found in Manual. ;O)
i'm gonna replace mine soon...
Bentley says 10 Nm (7 ft lb) for the bolts.
i got the oem gasket for a little over $10.
Not sure if you are supposed to use any sealent. anyone?
hunterp27
11
12-16-2014 08:44 AM
Damiano
06-07-2007 12:33 PM
egp320i
14
05-31-2005 08:44 AM
Ghostfire
09-05-2004 11:22 AM
