Anyone know a good website that can tell me how to wire a CAP into my car audio system
I got some headlight and gague cluster dimm when my bass goes, so I need to install one or two of the 1 Farat CAPASITORS that I have.
...then connect the Power lead you have coming from your battery to the +ve terminal of the cap which in turn goes along to your Amp's 12v terminal.
Unless you're running over 500watts of power, you don't really need a CAP. You probably need a new battery or perhaps your alternator is starting to show it's age.
and it's farad not farat. 1 farad at 12volts will hold a ****load of charge, make sure you don't cross the terminals because it will act as a welder and fry anything that conducts good enough. And get the polarity right because most caps will explode when connected backwards.
be careful when hooking it up also, at first it will try to draw an infinite amount of current -> battery may boil if it is small enough. But if this is the case then you needed to upgrade your battery instead.
Ground 0--------------0----------------0 AMP -
(CAP -)
xxxxxxx
(CAP +)
12V 0-----------------0----------------0 AMP +
'0' represents a connection
since this isnt posting correctly, the cap - and cap + connect to those two 0 in the middle of ground and 12v
enjoy
(CAP -)
xxxxxxx
(CAP +)
enjoy
Lucas Larson
02-27-2020 09:37 AM
A4_Jax
09-17-2004 09:20 AM
HACK THS
11-14-2003 01:41 PM
