anyone know if this will work on B4's?
the beginning of page states instructions are for "relayed" heated seats (pre 92)
the exact procedure I am wondering if it will work is..
"Method two: You can simply splice wires on Connector A and bypass the "backrest" heater. If you choose to do this, on Connector A, cut the jumper wire, then splice the wire from (5) into wire (1). You can leave the loose wire at (4) disconnected."<ul><li><a href="http://www.mnsi.net/~natwhite/Audi/heater.htm">complete document</a></li></ul>
...system was used. Basically, if you have a seat heater relay then this system CAN be used!!"
quattro.pilot
08-31-2008 06:47 PM
QuattroHawk
12-07-2007 05:27 AM
Fox-2-4kq
11-08-2005 05:23 AM
