Anyone repalced their original aerial?
hi guys,
Have any of you replaced your original aerial with an after market one?
mine is stuck up and no longer working and wanted to change it for a different one i can at leat push down.
any advice/help would be great
thanks in advance
thanks in advance
Since I know you have a Cab, I'll tell you the problem. If you are lucky, the plastic antenna cable has snapped. $45 at Audi for just a new mast. Usually, the metal drive gear inside the power antenna eats the plastic gear. This happens because the plastic gear fits into a spring loaded slip fitting that acts as a clutch to ensure the antenna is totally retracted before the drive motor cuts off. If it binds, the plastic gear teeth get eaten. Way too much engineering in this system. The plastic gear can look OK, but inside where the two gears mate, it is stripped of teeth. The fix for this, to keep it original, is to get a junk one and inspect the gear before paying for it. New antenna assembly is rediculously expensive from Audi and you can't just buy the failed part. I haven't found a suitable replacement and I need a back up, too.
s.cars
13
02-02-2005 04:54 AM
quattromano
04-20-2004 08:12 AM
