Auto to manual seat swap?
Ok, I searched the forum. I've come up with varying info. Some say swap the metal bottom so the manual seats will fit. Others say it requires cutting/welding. I hope it's the first...?
Also, is it true that the '95 90 LED heated seat switched won't work in my '90 20v? I think I heard that the switch will smoke? Or is that the other way around?
Thanks!
Thanks!
...otherwise, the side rails between the power and manual seats are the same. So pretty much, I think what you need to do is weld in that middle support bracket that the front of the seat attaches to in order to slide.
When we did the manual --> power seat mod in my car, we had to cut that bracket off/out.
<center><img src="http://www.oakvillesound.com/pwrseat-1.jpg"></center><p>Here's a look at the bracket attached to the car (originally equipped with manual seats). So this is the bracket we cut off to go manual-->power.
TEB
06-14-2007 05:57 PM
zeems
19
11-04-2006 08:21 PM
