Aux Gauges Dim, 4 volts at each globe?
G'day guys, I have just installed the B4 aux gauges into my B4 quattro. Everything went smoothly but the illumination is very dim....I'm talking barely lit! I stuck a multimeter on the globe connection and I'm only getting 4 volts. I traced the 12V illumination feed on the aux gauges PCB and there's a resistor on the PCB that cuts the voltage from 12v to around 4V before the power eaches the globes. Is this normal? should I:
-replace resistor?
-bypass resistor so globes get full 12V?
-put in higher wattage globes?
Any ideas on how to solve this?
George
Cheers
George
-replace resistor?
George
Cheers
George
Checked dimmer, was at about 95% already. Aux gauges need to be about twice as bright as they currently are. I'll hunt down some 2 watt globes, but I'm still bugged that I'm only getting 4V at each globe.
George
George
QPower95
05-30-2010 07:20 AM
UrS4boy
Audi Original "S" Cars
04-01-2007 11:11 AM
RedBlackYellow
01-30-2007 06:55 AM
sidespar
03-11-2002 07:12 PM
