On a B3, if the key goes in the door lock and doesn't have any resistance when turned...
...so the door doesn't lock (but still locks from the inside and locks when the key is placed in the passenger side door) what is the usual culprit?
And unless your car has an alarm, you probably have the assembly on top. The one on the bottom has the switch for the alarm. I think it does the window roll-up/down thing too. Item #17 on the bottom would be it if you have that setup.
...specific to the top diagram is not available - only the bottom (or shared between the two).
rwish
9
11-24-2015 06:03 AM
Mike Desi
03-05-2008 05:48 PM
MontcoPaA4
02-09-2005 02:06 PM
