Bad Valve Stem Symptoms?
Old 06-16-2010, 03:12 PM
uglybaby's Avatar
Default Bad Valve Stem Symptoms?
The 12v has been misfiring after driving for ten minutes or so. Seems to be after getting up to temp. Can oil consumption from bad valve stem seals cause missing? Fouling the plugs maybe? It runs fine after you shut it down and let it cool. Starts up again after ten minutes or so. I'm also blowing smoke after car is warm at low revs and idle.
Old 06-16-2010, 09:16 PM
CRAZY_RUSSIAN's Avatar
check your compression first... i dont c how valve stems could cause a miss... but odd things have happened before
quattro2turbo
12v V6 Discussion
10-09-2006 04:50 PM
The S
04-04-2006 05:15 AM
smoldyr
03-11-2006 06:25 AM
sylbry
04-14-2001 10:02 PM
Quick Reply: Bad Valve Stem Symptoms?
