The bew ignition switch is in. No dice. LOOK inside tell me whaat you think
#22
A voltage spike from the alternator, can cause damage to any component of your electrical system...
Might be other problems with the electrical?
Has the lid on the fuse box under the hood been off during rainy weather?
Aftermarket radio installed? Hows the wiring for it? I've seen quite a few aftermarket radio wiring nightmares!
Anything else electrical recently installed/repaired?
Might be the trunk-lid wiring, shorting out?
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
#23
Starter is shot. Now I may be wrong but the fuel circuit operates in hand with the starting circuit. I think you need too score an electrical schematic to see how everything is wired into each other.
#24
Well there is a horibly installed stereo and the battery is reading 17 volts. But the stereo is still working. The engine shut down while i was driving. I noticed it and turned the key and it cranked over but, didnt start, then i pop started it and it ran for another 1/4 mile then shut off again. Then it wouldnt turn over at all..
#25
Sounds like its being over-charged by the alternator, as the voltage regulator on the alternator is allowing the battery to charge too much....
17 volts can cause all sorts of problems for all sorts of electrical components...as most can only handle 16 volts max...
#28
<center><img src="http://img.eautopartscatalog.com/live/F401057791BOS.JPG"></center><p>
considering its age, and wear? Plus the VR brush's rub on the copper rotator, are often worn, causing problems for new VR's.
The cost of a new VR, verses the cost of a rebuilt alternator? ;O)
