brake problem... or is it....
AudiWorld Expert
i posted earlier about stuck calipers so i went ahead and installed new calipers, pads and rotors.....
everything seemed fine until i took a 15 min drive on the highway. When i got to the destination the same caliper is all heated up and it seems like it's stuck again.. but this time with new calipers and rotors.
On the same axle the wheel bearing is toast (found out at repeater's house) but doesn't seem like there is sound or play while driving.
is it possible the toasted bearing causing the massive heat enough to expand the rotor to the point of sticking?
AudiWorld Expert
i had to cut the end ball to change the caliper
driver side (where the problem is) the cable moves fine.
however i will DC it and see if it helps...... tomorrow
aebarto11
02-17-2018 09:43 PM
oskidunker
10
05-05-2003 08:35 AM
