Brake question
Old 03-22-2010, 03:27 PM
Typ89's Avatar
Default Brake question
Hello,
I've got some issues. I have a B4 90 FWD, and was planing on replacing rear rotors. I got old ones off of a car tried installing new ones, but gave up on that because there wasn't enough space between the brake pads, tried installing old ones same problem. I can't seem to decompress piston, i removed the bleeder bolt that didn't help, I then removed the entire caliper took it to a shop and tried compressing it with a vice didn't move. I don't know what else to do, it freely moved forward, I tested it using e-brake lever on the caliper, now piston is as far in as it could possibly be.
Does anyone know how to decompress it?
Old 03-22-2010, 04:57 PM
CRAZY_RUSSIAN's Avatar
OW MY... i hope u didnt destroy your caliper!
you have to rotate the piston while applying pressure on it, its its a pita, but its duable.
or you can get a special vw/audi brake tool that will turn the piston while the pressure is plyed
Old 03-22-2010, 04:58 PM
btw, its clockwise as you are looking at the piston
Old 03-22-2010, 05:04 PM
maineman's Avatar
Default proper tool
The rear caliper has to be turned while pushing in .You need the proper tool which sometime can be loaned or rented at some parts stores.Here's what it looks like. Do you have a repair manual?
A search for rear brakes or rear calipers would have got you some answers.hopefully you didn't ruin anything with the vise.
good luck
http://cgi.ebay.com/ebaymotors/NEW-B...motiveQ5fTools
Old 03-22-2010, 05:06 PM
yep, or check my sig on facebook, i posted a picture of the tools i used, worked out just fine for me :-D
Old 03-22-2010, 05:22 PM
Typ89's Avatar
I thank you both very much, everything is put together now and I didn't destroy the caliper!
Old 03-22-2010, 11:54 PM
glad we could help :-)
Old 03-27-2010, 08:19 PM
Typ89's Avatar
Hi again, is there a special way of bleeding brakes? It seems like no matter what I do they remain "spongy". By the way, I've finished installing my new rotors today, the size is stock but they're drilled and slotted, also zinc coated. They look nice but perform even better I'm still using my old brake pads and I've noticed a world of a difference. Will post pictures later.
Old 03-27-2010, 09:33 PM
stop wright there! replace the pads before they seat in with your new rotors!
otherwise youll have a set of rotors that are set in with the pads, then you replace the pads and the rotors will not seat in with the pads as they are supposed to again.
for some reason my repair manual keeps crashing at start up... but if i remember correctly start on the right rear first..
Old 03-27-2010, 10:04 PM
Bleeding sequence
1 - Brake master cylinder (if equipped with bleeder screws)
2 - Right-rear brake caliper
3 - Left-rear brake caliper
4 - Right-front brake caliper
5 - Left-front brake caliper
Quick Reply: Brake question
