brakes won't stop squeeking..any quick fixes
Old 11-10-2004, 01:43 PM
Senior Member
coupe d'mike's Avatar
Old 11-10-2004, 01:53 PM
|skolnick's Avatar
Default lube
the parts where the pad backing contacts the caliper carrier and caliper piston. DO NOT put any on the brake pad face or brake disc. Use caliper slide lube. This is too much lube, but you get the idea.
<img src="http://pictureposter.audiworld.com/46079/img_1953.jpg">
Old 11-10-2004, 02:12 PM
repeater's Avatar
Default Yes, and it does work....
In theory, pads will vibrate inbetween the caliper ever so slightly, creating harmonics that go through the calpier and rotor when you are lightly on the pedal. Think of the rotor like a big "bell". The lube works like putting oil on a squeaky hinge, only it's silicone based and won't dry out. My Hawk HPS pads on my S4, w/993 big reds squalled like a angry Banshee for two months after putting them on - I got fed up and took them off and used some of the silicone grease I always used just for lubing the slides - I haven't had a single squeak since then. I used to use the 3M tack spray on the backside of the pad, but came to find out that all that stuff does is bond the pad to the piston of the caliper, then both the piston AND the pad vibrate. The grease works better.
Old 11-10-2004, 02:28 PM
Senior Member
thanks. i'll give it a whirl
Old 11-10-2004, 08:09 PM
Junior Member
Julian_B's Avatar
Default Grind a 45 degree angle on the sides of the pad
a 90 degree angle from pad to rotor will sometimes cause squeaking.
Old 11-10-2004, 08:23 PM
Junior Member
JazzGuitarist's Avatar
Default also try
<center><img src="http://www.vetteweb.com/tech/0310vet_baerweb06_s.jpg"></center><p>
ScottJ
03-31-2005 12:11 PM
obLu
06-17-2004 03:15 PM
wmbear2019
Audi 100 / A6 (C4 Platform)
04-23-2004 12:22 AM
a8silver
08-07-2002 06:09 AM
mdwsta4â„¢uroslut
04-16-2002 08:08 AM
Quick Reply: brakes won't stop squeeking..any quick fixes
