Broken shift linkage
Went to shift into reverse tonight and heard a clunk and there was nothing, just free play. Got underneath and it looks like the rod for the gearbox and the shifting box were spot welded in three places and they all broke free. I'm running a 2B 6 speed. Has anyone ever taken apart the shift linkage or installed it when the exhaust and driveshaft were in place? I'd hate to tear the whole car apart to get to it but will if I have to. All help is greatly appreciated.
You can get a 10mm socket on a long extention on it. 13mm for the bottom of the shift lever. Getting if apart is easy, getting it back together... that's the hard part if you don't have easy access.
I see the 10mm bolt at the gearbox but didn't think that was all that held it together. Does it just pop out of the big fitting that I see below that? I've already got it apart at the shifter, just need the long connection to the gearbox apart so I can get them re-welded.
like standard B3's and B4's have then it will fit right in. If not then you will need a different part. I am almost certain that they are the same.
rakta *chchchanges
03-18-2009 02:00 PM
AxeYrCat
24
01-23-2008 02:32 PM
SupraTL
07-02-2006 01:01 PM
