can any one share from a past experience...
bout diagnosing a no start on a 95 90Q 2.8. iv exausted all i know bout no start diags and cant come up with anything, so has the dealer. i still hav no spark and injector pulse. i have crank, cam and RPM sensor signals back to the PCM also fuel pressure. wat else can the PCM need to fire her up. pls help, thanks
i pulled out the ignition switch and jumped the terminals controling the ignition system. i went ahead and changed it anyways. how would the coolant temp sensor stop it from starting? i know there is a seperate sensor on the right rear side of the engine that looks like a coolant sensor as well. which one feeds the temp guage. i have put in new crank and cam sensors, RMP sensor in bout 5months ago cus i had a code for intermnt faults and it run fine for a while.
<center><img src="http://www.12v.org/engine/images/rear.gif"></center><p>...and again IIRC, while the G62 works with the ECU; the F76 (MFTS) works with the T-gauge, and A/C (hence the "Multi-Function" moniker).
I don't believe this (below) is correct, however:
<ul><li><a href="https://forums.audiworld.com/12v/msgs/56164.phtml">functional coolant temp sensor required to start engine apparently...</a></li></ul>
shinto99
08-19-2011 03:41 PM
Holographic77
04-03-2006 08:12 AM
Žob
02-17-2003 08:04 AM
a4neil
02-18-2002 09:06 AM
