Can someone explain why torque on a bolt will be so many foot pounds PLUS a fraction of a turn?
Why specify the fraction of the turn? Why not just up the torque? What am I not understanding?
using a predetermined torque value sets the initial level of friction where stretch is a known value (pretty much zero stretch at that point). Then the angle dictates how much load is applied based on the type of threads.
http://www.rv8.ch/article.php?story=20051227112926716
http://www.chevyhiperformance.com/techarticles/49258_rod_bolt_torquing_stretch_info/
That's why its critical to use the recommended lubricant (or to remove all if it is recommended). Lubrication changes the friction values.
tried reusing the big bolt on the outer CV... don't even bother... *snap*
Atleast when you release the tension on them the broken part unthreads really easily... long needle-nose vicegrips anyone?
the only time the broken part will be "stuck" is if it is bottomed out in the thread bore. those are a serious PITA to remove...but in that case the bolt was too long to begin with. :-(
snarlofdisgust
05-07-2010 09:01 PM
Mr. Malcontent
12v V6 Discussion
18
03-13-2005 01:36 PM
evils4
09-19-2004 07:36 PM
LJ.925
03-06-2004 10:00 PM
Object
10-11-2001 04:25 PM
