Can't get O2 sensor off. Need help!
'91 90 20vq
The sensor is just before the cat (not downpipe), but i can't manage to fit a socket or wrench over the back of the sensor. anyone else have this problem? will i have to take it to a muffler shop and have them drop the cat out to change it?
so you can't get a 22mm open-end wrench on it, or the special 22mm O2 sensor socket on it? Those are about the only two things that'll fit on it.
Also, read on the 20v.org site for O2 sensor changing on the 20v cars.
What you're describing, seems like the same thing in the coupe's. Use the 22mm closed end. But Dremel the top. Take out a .25 to .5 inch out of the top. This will allow you to slide it in around the wires, then slide down to the bolt. The open end is to thick to get into the bolt, so this fits nicely. Hope it helps
I'm following the 20.org directions. The only problem is, the space is not long enough for me to fit the O2 specific socket over the back of the plug. It seems like most people have done this themselves, so i might just need to find the right entry angle to get it on. maybe?
<img src="http://pictureposter.audiworld.com/52843/oxygen1.jpg">
<img src="http://pictureposter.audiworld.com/52843/oxygen2.jpg">
<center><img src="http://www.skywaytools.com/catalog/images/4491c.jpg"></center><p>
Especially since I have broken several of the other O2 sockets! ;O)
siegen
03-22-2024 08:53 PM
jimzigg2
04-23-2008 05:40 PM
OldSchool AG
02-08-2006 12:49 PM
