cheapest place for V6 timing tool?
Due to the fact that the belt sprockets do not have a key way it is a tapered fit there is no way verifing cam timinig without the tool. You are making the assumption that the cam timing is correct what if it isn't??? If you are changing the belt do it right.
I've done countless t belts without the tool- but recently even after it's checked with my long bar method, after you tension the belt, (yes, I do loosen the sprockets so they spin freely).. the cams are probably about 1-2 degrees off from the crank timing.. Thus deciding that the tool is really the only way to do it right correctly, with out having to redo it.
and HE brought the tool, because the mechanic who swore he did timing belts for 30 years and could do any car couldn't do it on my Audi.
Catamount90
09-06-2006 01:54 PM
fussball.biturbo
Midwest Discussion
06-19-2006 02:19 PM
OldSchool AG
Southeast Discussion
10-26-2005 08:54 AM
GrandPaJohn
11-11-2002 09:39 AM
