CHECK ENGINE LIGHT Success Story
Well it took me several weeks, but in the end, the solution was FREE....hope this can help somebody:
SYmptoms:
check engine light is on(duh)
engine often conks when cold
NO power above 4000rpm
stumbles when coming off a stop light and when down-shifting
Temp guage is funky
Tried Replaceing multi-function temp sensor but that did not do a damn thing (even for the temp guage).
So then, with cryptic and sketchy advice (*******!) from you guys, I found www.12v.org and learned how to pull fault codes - took less than 10 minutes total.
Code:2324
Problem Area: MAFS
Actual Fault: blown fuse; 10 amp left-hand engine fuse (#27). Replaced with spare.
Result: Every problem cured. (temp gauge is still stoopid)
Hope this helps!
PS: I wish I'd known this when I had to drive through Montana and race a new Jag and Chevy Suburban who beat me when I ran out of breath above 4000rpm. DRAT!
SYmptoms:
Temp guage is funky
Code:2324
Problem Area: MAFS
Hope this helps!
these are the ones located directly umder the 1-21? becasue theres only 5 fuses under the big row and i understand i dont need a few of them. but im not sure what fues you are talkin about?
