couple of exhaust manifold questions
('94 90S Head Gasket Job)
I have both heads off and the 3 exhaust flange studs are in pretty rough shape on both sides. It looks like there are no threads left where the nuts used to be. How should I handle this?
1. Do the studs thread out of the manifold and can be replaced?
2. Should I drill them out and replace with tapped holes?
3. If the nuts thread back on, should I just reassemble it as is?
Thanks for any help!!
-Erik
-Erik
They unscrew from the manifold, but you will need to heat the manifold up cherry red to get them to budge. If you don't have a torch, take it to a shop and have them changed. You will not need to remove the manifold from the head to do this. Buy new studs from the dealer.
Pat
03-17-2016 05:28 AM
Pre95
24
09-12-2008 12:44 PM
ItsSpecial
03-14-2007 10:36 PM
Audi-Impaired
04-08-2003 09:01 AM
