cv joint removal
i did read the writeup on how to do it, but i still have a quick question. the only thing that holds the outer cv joint on is a circlip? so once you use the bolt to pull it off to put it back on you just need to use a plastic hammer to tap it on? doesnt seem as hard as it looks, hopefully.
put a new circlip on then just tap it on with a soft hammer till it "snaps" onto the ring and your home free?
I am debating whether i want to removed the entire shaft or if i can work on it with my strut assembly in the way
euclid
Misc. Models Discussion
09-28-2001 04:53 PM
DavidFeygin
12-20-2000 08:23 AM
