damned miss won't go away.
changed o2 sensor, temp sensor, plugs, cap, rotor, found a vacuum leak. also slight power loss from 3500 - 4200. haven't pulled the codes yet.
next on list??
a. cat
b. replace all vacuum lines
c. suck it up and take it to a shop
i'm at an impasse.
next on list??
a. cat
i'm at an impasse.
you can test the resistance of the sensors to individually diagnose them. and any sensor that is not contacting correctly and not sending signals to the ecu will send a code. if the ecu is not functioning properly, then yes a bad sensor may not give a code.
I had a different power loss due to bad knock sensor wiring , couldnt figure it out for a while but as soon as i pulled the codes i had it fixed in a day (and a WAD of cash for 2 sensors)
jimzigg2
04-17-2008 08:14 PM
yanbu
10
08-31-2007 08:37 PM
