Daytime Running Lights
Anyone ever disconnect these on a Canadian model? My car (1991 90CS) was originally sold in Canada.
Don't like to shine my headlights on my neighbor's houses when pulling in the driveway, but can't shut the dang things off....
Front Park Lights, Tail lights and headlights are all on at all times the key is in the ignition. There must be some simple way to stop that.... Thanks!
Re: Daytime Running Lights
Well, that sounds simple enough. I suppose it is under the dash. No jumpers or other changes necessary so that the lights work at "normal" times (i.e., when switched on)? Thanks!
Just wondered if anyone had done this & experienced bad after-effects
or needed more adaptations to keep things functioning normally.
The scan was a lot better, but Audiworld automatically reduced the resolution (from something like 1000x800 to something like 320x240).
Sometimes, when you pull a relay, something else happens too. Or, for example, in the 20v.org files, there is a Mod so you can use your Foglights w/o the headlights being on, but when you pull the relay, you have to replace it with a jumper. So, I was looking for someone who had the experience of doing this...
Troy H
TT (Mk2) Discussion
10-05-2008 08:34 PM
a_o_smith
11
07-06-2005 06:49 AM
Mr. White
05-05-2003 02:07 PM
