With Depos, driver side headlight is proper brightness, pax. side is very dim, also when highs are..
...flicked on both lights cut out completely.
With just the lows on the high beam light illuminates very dimly.
Sound like a bad headlight switch?
...just Depo over Bosch headlight. Direct tit-for-tat swap....what am I missing?
many times people mess up the ground, low hot and high hot connections to either the relays (if installed) or the bulb sockets. My first attempt 7 years ago taught me a lot when there were some dimming lights. IIRC the H4 bulb connectors looking from the back are-- top horiz is low bm (yellow) right vert is high bm (white) and left vert is ground (brown)
...I assumed they just screwed the headlight assembly in and plugged in the factory wiring connector to the headlights.
Nothing looks hacked or wrong from what I can tell...
on the back of the headlight housing, you connected a 3 or 4 prong connector, cant remember, but they are 4 circular type conical pins. They fit in more than one way, rotate the position it is in, and that headlight will work properly.
Thats for sure what it is
