With Depos, driver side headlight is proper brightness, pax. side is very dim, also when highs are..
Old 09-19-2006, 11:35 PM
  #11
zeems's Avatar
Default On the set I had, the connectors to the bulbs were not very tight...
...it helped to wrap a small amount of wire on the bulb terminals, so that when you put the connector on it was nice and tight. I had the same problem with a dim right headlight.
HTH.
Old 09-20-2006, 05:56 AM
  #12
SCarGo02's Avatar
Default I messed around with the headlight for about an hour or so last night...
...the bulb connection is just fine...as is the connection to the headlamp from the factory wiring. I think it's upstream of the headlight...
Old 09-20-2006, 08:26 AM
  #13
Just Paul's Avatar
Default Chase it down to the next connection, then check the voltage @ the fuse vs. battery
and that should isolate it to cabin or not.
Old 09-20-2006, 11:39 AM
  #14
SCarGo02's Avatar
That's what I figured, anyone have any idea where the next connection is upstram of the headlight?
LuvmyQ5
05-03-2022 12:42 PM
SCarGo02
12-29-2006 07:31 PM
2.7 Husky
05-02-2005 05:25 PM
eroc
12-24-2002 01:47 PM
wetzerk
01-14-2002 02:21 PM
Quick Reply: With Depos, driver side headlight is proper brightness, pax. side is very dim, also when highs are..
