Digital Climate Control interchangeability?
Hello
I got a 1995 90Q and the Digital Climate control is going crazy. I was told the outputs are bad.. I'm guessing that's probably the main board? The part number for the one in the car is 8a0 820 043 f. I called a dealer and was told the one for the car is a variant of the part number above but end in g (8a0 820 043 g). I've seen others on ebay that end in 'e' or 'd'. I'm wondering if anyone knows if they are all interchageable. Although the "Hella" part numbers are the same the 5hb 006 500-01.
hmm, anyone able to shed some light?
I would guess that any UrS car and A6 of the same style all are the same. Maybe even the early A4s.. You can go to a junk yard and just give one a try...
All the control modules look the same and plug right in but they are different and cannot be "recoded". Look at the sticker on the unit: it has the chassis code on it. C4 units do not work. You need something from a 1993 90 to a 1996 A4 B chassis only. If you want the illumination to match, 1995 90 and 1996 A4 are your only choices.
A/C control head coding
1st and 2nd digits (where applicable)
Code Description
00 _ _ _ not used
3rd digit
Code A/C compressor type
0 _ _ Zexel
1 _ _ Nippondenso
4th digit
Code Engine application
_ 5 _ 5-cylinder
_ 6 _ 6-cylinder
5th digit
Code Market version Engine type
_ _ 2 USA/Canada Gasoline
Below that it even tells you how to...RE-CODE it. ;o)
Code Description
00 _ _ _ not used
3rd digit
0 _ _ Zexel
1 _ _ Nippondenso
4th digit
_ 5 _ 5-cylinder
_ 6 _ 6-cylinder
5th digit
