Do the front sway bar brackets usually come out easily?
but there is VERY little space to get a nut or bolt thru. I had a friend plasma cut off one side of that "bracket box" so I can put a nut and still hold it with a wrench. I took just ones side off, the lateral side Its just enough room to get a 13mm wrench in there so you could pinch bolt it down. The old nut just popped right off from the plate. Not sure why or how but it did.
