do i need a hub puller to press the halfshaft out of the hub?
That's to get the CV off the shaft, is that what you mean? The CV/axle assembly will pull out of the hub by hand once the ball joint is disconnected.<ul><li><a href="http://www.20v.org/drvshaft.htm">Step 10</a></li></ul>
AudiWorld Expert
i know some cars u need a hub puller to get them apart...couldnt recall if i needed one for the 90.
No Bozos!
We just did two that were stuck.
If you can get it up on a lift you can generally work them out, but on stands on the ground it's a lot harder.
Sometimes they're fine and sometimes not. When you're in a hurry is when they usually give you a problem.
anon_az
07-01-2009 02:24 PM
Merkin
14
06-11-2006 09:23 PM
iVTEC Yo(ex-B5er)
05-04-2005 03:49 AM
