Door lining removal ?
Anyone got any idea how the door linings are removed on a 90. I seem to have a bad window switch. I assume you need to remove the lining to get to the switch. Suggestions?
Here is what I did for the back door panels.
On the top of the inside and outside of the door there are two small black screws, remove them. Now the door handle has one visible screw, unscrew it and remove the top plastic piece of he door handle, the bottom will come out easily now too. Now you have the last two screws visible. Unscrew them and then push upwards on the panel and it should pop off. Hope that makes sense to you.
one side of my car has the pleather insert poppin out and the back passenger side door lock is shoved all the way down...so i need to remove the door pannel to get it but the only problem is the door cant open cuz its locked..how would i fix that?
Bisqueth
03-31-2009 02:24 PM
Audi_2000_1.8t
10-16-2001 02:40 PM
jetboy737
12-16-2000 12:41 PM
DFess
Misc. Models Discussion
11-01-2000 06:21 AM
