door trim
well the door trim on my 20v sedan is coming off. what do you guys think i should do? should i remove and repaint, should i replace it, get something better? whats out there?. i also want to take off the lower door trim and use a spray on material. give me some of your thoughts and ideas. Thanks
<center><img src="http://www.2bennett.com/deangreen0.jpg"></center><p>but the 2b car has it off and the side molding is painted....looks tight
there is a small possibility of water getting into the cabin:-) U can try it urself, u just slide the trim off and u'll see. It's not glued or anything so u'll be able to slide it back on with no problem.
BTW audi meetup is tommorow, 2 new 93 90q club members are gonna show up:-) Support B4 community fungus
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
and through that gap I could see the side of the first step when u open the door thats why I started thinking that water could get it:-) I thought those clips were glues or something, so I guess heat gun will help to get rid of them. Gotta be carefull and put aluminum foil on the door part so heat wont damage the paint. Got some pix of urs?
