Engine issues or electrical
I have a 1993 Audi 90CS. Was sitting at a light and the engine just died. Dash wasn't lit up at all. If you try to start the car the engine spins, but doesn't start. Has anyone had this problem? It seems i've lost the engine spark. Before I go spend thousands of dollars to have it checked out, any suggestions?
The alternator belt was broken at the same time, but the Audi shop said that was just a coincidence and has nothing to do with this issue. All other belts are in place and ok.
the crankshaft or camshaft position sensor. Those are sensors that when they fail, your engine won't fire. They seem to be failing on a lot of V6's lately. Could also be fuel pump or relay.
HTH
HTH
Do you have to take it to the dealer to pull the codes on a 93? I looked into buying a obd2 but they only make them for 96 and above. Thank you
shxuila
12
04-23-2017 09:18 AM
5000CDQturbo
08-21-2008 12:37 PM
