Euro (hella) H4 headlight adjuster motors/harness FTW...
What a pleasure to find a friendly German that dug up a set of these for me!
<img src="http://pictureposter.audiworld.com/110037/audi_276.jpg">
(Now I have to send him a canoe to reciprocate
So, anyone who has done this recently <cv tech, scargo02 etc>, can you help me confirm 3 of the wires. After much searching, the latest info I found was from cvtech this past March in this schematic..
<img src="http://pictureposter.audiworld.com/110037/headlight_adjuster_scheme.jpg">
So, the brown to ground .. easy.
The yellow to 12v constant power? or switched? (My educated guess in 12v constant)
So the black w/ blue stripe. This is for illumination? Or does this go to 12v constant or switched? Anyone tested to be sure?
<img src="http://pictureposter.audiworld.com/110037/audi_277.jpg">
Illumination makes more sense to me, but I would love to know for sure b4 hookin' it all up. For such a hard thing to find, it seems to easy to hook up..hehe...but I'll take it ..
and yes, brown is ground, yellow I wired 12v switch but from the headlight switch because you wouldn't need these with the headlights off, and blue with black for illumination but my illumination doesn't work probably because of a bad bulb in the switch but thats unconfirmed because my lazy *** just haven't done it yet.
I see a white wire going to the connector for the switch. On everything I've seen, a white and blue wire is used for illumination. However, Audi may have switched it up here.
what I found to work. Thanks guys...
I've got 3 switches..both a b3 switch that matches better, and 2 new switches (pics later depending on what works) so I'll know for sure if it's a bad switch or not.
the adjusters plates I think work different may wanna confirm that you can even use em, I mean is there a spot on the back on the headlight to put em?
I love audiworld
01-12-2003 09:26 PM
Audicted2quattro
08-18-2002 04:33 PM
shehatezme
12-10-2001 10:11 PM
SmokinS4™
07-17-2001 09:47 PM
