Exhaust? MikTip...
When you had your Moroso resonators did you have a rear muffler or just tips? I am going with the moroso setup but not sure how it will sound with just a tip? Or should I go with a tip that has a resonator build in on top of the morosos? I don't mind the deep exhaust sound I just don't like the dronning and I also want the best flow.
The Moroso's replaced the 2 center mufflers.
The Moroso's alone with no rear muffler, are quite loud, and sound like you "need" a muffler.
I have a Ultra-flow rear muffler which is of "straight-thru" design. Combined with the Moroso's, it sounds pretty good.
I've recently replaced my Moroso's with 2- 4"x 14" Magna-flow resonators. Much smoother sound. Still deep, and of same loudness level, but more smooth.
The Moroso's have a sort of "can" sound at certain rpms. Originally I placed them "in-line" after the 2 into 1 connection. This proved to not be ideal with the V6. I then installed an "X" pipe right after the cats, then the Moroso's, side by side, 1 for each bank of 3 cylinders. However the can sound was still there. So I went with the Magna-flow stainless 4" rounds in their place.
Lots of experimenting with my exhaust system!
Prior to all this I ran the OE center mufflers, without the rear muffler. Only had tips there.
Sounded pretty good!
Go to www.magnaflow.com From there you can find a supplier in your area.
Diagram? My systems constantly changing! ;o)
I've describe it in detail several times here in the forum.<ul><li><a href="http://www.magnaflow.com">http://www.magnaflow.com</a</li></ul>
audi-driver1126
09-12-2010 04:08 PM
JeromeS.
03-30-2004 06:02 PM
OscarM
02-21-2003 09:38 PM
VenomousA4
12-15-2002 12:21 AM
