Fault Code 2232 (MAF and wiring)...question
Guys need some assistance, B3 - 88 90 quattro, (5 cyl)
I pulled a fault code of 2232; now I was under the impression that the NG motors did not have MAF sensor?...
If I am wrong what's 2232? Location?, and direction to fix this problem?
Thanks in advance
---search--- reveals info regarding the B4 not B3 :0)
Thanks in advance
Airflow sensor potentiometer. ECU is not getting a signal, or the signal is not what is expected. Check the wiring to the airflow sensor pot. Also, are there any other codes...like full throttle switch?
No other codes except 2232, seems like the check engine light comes on after the car warms up.
Where can I locate this a.f. sensor pot?., (remember 10v)...
thanks
thanks
<center><img src="http://pictureposter.audiworld.com/78871/engine_bay.t.jpg"></center><p>I am thinking there in no a.f. sensor in a B3
thanks
thanks
GinCQ
14
07-11-2008 09:29 AM
