front strut bar
so i was talking with my shop teacher today and i asked if i could make a front strut bar for my 1991 20v90q sedan. he said being in some drawings and measurements and ill consider it. so does anyone have any drawings already made? id need the mounts and everything. i know some
of you make your own parts so i thought it was worth a shot. thanks guys
Either base it off of the Jamex design but do not make it with the bend, make it strait across. Or another idea would be to find some brackets from a 90 for the stock 90 bar and have them welded to your car. Next use the dimensions of the stock 90 bar to make a better bar
. Good luck. If you don‼sup>TM</sup>t have the option of taking the dimensions from a 90 I will provide them for you just ask. If I had AutoCAD on this comp I could draw it up for you as well. Wouldn't AutoCAD just be nice to have?
i actually have access to autodesk inventer which is like autocad but easier. i have autocadd but use it for landscaping. could you give me those dimensions? and what kind of thickness do you think i should go for? thanks man
<center><img src="http://pictureposter.audiworld.com/69679/bar_length..jpg"></center><p>The bar is aprox 37 3/4 long the bracket is aprox 1 3/4 high and 6 inches long. It goes around the upper strut mount and is tack welded down from what I recall. I wouldn‼sup>TM</sup>t make the bracket but I gave the dimensions of the height and length so you could draw one up or something. Now you need to work something out with the boltholes.
Sloooo4esT
Audi Original "S" Cars
02-22-2009 04:15 PM
snowchaser
07-13-2006 08:08 AM
StormChaser404
04-15-2003 01:34 PM
