Front Windshield Washer Problem
Driving to work today, my front windshield washers stopped working. To clarify further, they are not spraying any fluid. Are there separate resevoirs for both the front and rear wipers, because the rear works just fine. I haven't had a chance to check the connections yet, but any advice would be appreciated.
You do have fluid in there, don't you? If so there could be a break in the lines or your pump motor has gone to hell. I'd check the basics first, fuse,etc.
There is fluid, because the rear washer works just fine. I can hear the pump, but just no fluid. Are there two tanks for front and rear? I don't believe so, but I may be wrong.
Two tanks on my 1994 Coupe - front one is in the wing, near the strut tower, and has a big blue cap on it.
Rear one is in the right hand side of the trunk.
