Fuel filter removal question for 95 90Q
How do I get the fuel filter out of my 95 90Q? It's located in front of the right rear wheel next to the gas tank. Its mounted vertically and I can easily get the lower banjo fitting off. How do I loosen the plactic bracket that that the filter's attached to? I can see an allen head screw way up high but there is no way to get to it without removing the gas tank. Does the bracket somehow com off with the filter attached? Do you remove the upper banjo fitting after removing the filter? Help!
