Got Vally Pan cover off...does not seem to be warped and old gasket looks good??
<center><img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC00831.jpg"></center><p>could it just be that the bolts came loose???
There IS A HELLA lot of oil in the little crevases arround the lid...so this is where my oil leak is coming from.
<img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC00832.jpg">
but I have no idea how to actualy clean it?
think I might just skip them...although I'd like to do it while im down here.
just lettem be. They wont come loose and there's only 1 moving part inside (ball bearing).
Clean both gasket surfaces up with Acetone or laquer thinner, apply small bead of silicone around both gasket mating surfaces and bolt holes. If ya wanna do it REALLY right clean all oil out of bolt holes with Acetone on a Qtip and use a small dab of silicone on each bolt before torquing. Als long as bolts and threaded holes are 100% oil-free silicone makes a GREAT thread sealant. Then torque in sequence to spec and forget about it for 25 years or so.
I NEVER wanna go back in there again..lol
also by "torque in sequence" do you mean 1 after another all the way arround...or to cris cross as tightening?
<center><img src="http://www.permatex.com/images/catalog/gaskets/82180.jpg"></center><p>sealer.
This stuff is sooo good you can use it without the paper gasket! ;O)
If you didnt put that oil there then thats where the oil is coming out at. What I mean is the gasket might look good but its obvious that its coming out because the gasket should be dry of oil.
