Having oil pressure problems.
I recently installed the Aux gauges along with a two prong oil pressure sender. After hooking everything up The oil temp works. The Volts work they are reading out at 14v's when the car is on and 16v's when the car is off, is that right? My other problem is, even after installing the oil pressure sender, my oil pressure is still at 5 bar and does not move. I am almost positive I wired everything correctly. Everything else works in the gauges. Am I missing a low oil pressure sender or something? What could be the culprit? Thanks for the help.
Peace, Thomas
Peace, Thomas
