Help, can't get tie rod end out of arm
I'm replacing my tie rod ends and sway bar links now, one sway bar link done, but I can't seem to get the tie rod end out of the arm. I've whacked it a few times with a hammer and I've tried to move the control arm up and down with the OE jack to get it loose, no luck yet. Any Suggestions?
Since you are replacing the tie rod end, use a pickle fork, jam it between the end and the housing, then wack it with a hammer.
I had to use a very large sledge hammer + pickle fork to do my rear ball joints, and it STILL took a while.
Good luck.
Mike
Good luck.
Mike
