HELP! i lowered the 90 20V, but the rear is about an inch higher than the front!
and it looks really odd......
any way i can further lower the rear?
it has intrax springs with bilstein sport shocks
i DID notice that i has rear strut bearings that were in the mounts...but taking thoes out would only shave off about 1/4 an inch......
any help would be good! thanks!
don't have the problem you have. I think you may have the springs reversed. Either that or who ever sold the springs to you didn't send the right ones.I have the typical German slammed car look.
I have heard about this before on this forum. I think one set (fronts?) are progressive, and the other set (rears?) are not progressive. Check that out.
Mike
Mike
This is from the 20v.org site:
** Beware that the Eibach springs are linear in the front and progressive in the rear. This is opposite from what you might expect, so be sure your installer knows which ones go one which end.
I'm not sure if this is true for the intrax as well... but I did progressive in the front, and the linear in the rear like a "normal" car.. but found out RIGHT after I put them on that the springs I have(eibach) need to be reversed.
best of luck to you!
with the front end lower than the rear, 60/40 style, ugly as sin. Make sure the springs you got lower the car the same distance all around the vehicle, check P/N's of the spring kit with Intrax's catalog too.
Cheers,
Cheers,
...but it looks like you may need to break out the grinder and chop a few 'dead-coils' off to get it where you want it....
XcellR8edAudi
09-06-2004 09:33 PM
cabriolet rear springs (8G0 511 115a) are cabriolet specific springs fronts are same as B4 except 93
wisconsin_quat
15
09-05-2003 05:31 AM
Rhema
08-16-2000 08:29 PM
