Help with an overheating problem.
Ok, i'm new to this whole audi thing. i have a 1990 90q 20v, never had a problem. yesterday the upper radiator hose came off, and spilled all the coolent. no problem, i'm handy with a hose clamp, and fill it back up. drives fine all day. last night, the heat stops working. and car starts to run hot, i checked the coolent levels, they are fine, no leaks at all, there seems to be coolent circulation, at least i can feel hot coolent moving through the upper rad. hose. i am at a loss. i'm thinking t-stat, but it seems to be opening, maybe just not enough? any ideas are more than welcome. the lack of heat has me really worried, as i am wondering if i am getting flow to the heater core.
Thanks in advance.
Thanks in advance.
Air trapped in system. Use search and enter bleed coolant.
Here's one thread to get you started:<ul><li><a href="https://forums.audiworld.com/9080/msgs/71077.phtml">Bleed it... clickety click</a></li></ul>
Some coolants don't mix. Some can even "gell" in your engine. Do a search on 'coolant' and you'll find a million threads on this. Ok, well, a few.
Used to say, "Just use blue or red." But now, "just use Audi approved coolant, regardless of the color". There are too many variations out there.
Common problem with old radiators, they get clogged and will not let enough coolant through to cool the engine. Also causes excessive back pressure on the entire system causing hoses to leak or burst. Usually the upper radiator hose is first to go and that is most likely why your hose came off. Try some Prestone flush and if that doesn't work get a new/rebuilt radiator.
talltorontoguy
06-17-2005 05:56 AM
talltorontoguy
12v V6 Discussion
11-15-2004 11:40 PM
talltorontoguy
9
11-15-2004 10:06 AM
