Help with rough running coupe 20V
Searched the archives and decided to replace the fuel filter but this did not help. Symptoms are as follows: No codes set, idles perfectly, spark plug wires and spark plugs are fine, when trying to accelerate it acts like it is running out of gas, once I actually get up to speed on the interstate it will hold 75 just fine but if I try to accelerate faster it starts jerking again. It hesitates like this whether I am driving or sitting in the driving revving up the car. Any suggestions of where to start. TIA
or white marks on the long tubes? Whiteness coule mean a leak in teh seal and causeing it to ground out to the block. plugs? mostly check those first then get back to us.
They are the easy stuff to look for.
-JIMMY
-JIMMY
7A engine? You have got to be getting codes for such a condition. Have you got codes out before - not trying to denigrate anyone but simply eliminating possibilities. Are u getting the 4444 or the 0000 codes to indicate no faults?
I have had similar feeling problems that turned out to be knock sensor (for which I got codes) and injectors and fuel pump relay (for which I got codes) which turned out to be dirty connection in the connector in front of the distributor.
Wayne in Perth, West Oz
has it been replaced? If still OEM, then the teeth on the nylon gear are either worn or missing. Time for a change.
I am getting the 4444 to indicate no faults, am I missing something there? I checked the ohms on each of the injectors and am getting about 3.2 on each of them. I'll check out the fuel pump relay later today.
Thanks!
Thanks!
One of the spark plugs had completely died. Changed them all out and voila, perfect running car again, I also found the crankcase breather was not all the way together below the distributor which cures another problem I had with some leaking oil and horrible smell in the HVAC system. Thanks everyone for your help and advice!
Bebee
12-23-2007 04:47 PM
Audi_kraut
11-10-2007 09:39 PM
Quaboosttro
05-02-2006 02:31 PM
Pekboy
03-09-2004 09:02 AM
