Here are my emissions test FAIL results!!! Your advice needed...
Old 04-06-2011, 06:42 AM
vwdt2008's Avatar
Default Here are my emissions test FAIL results!!! Your advice needed...
It failed the driving part of the test but passed the idle part. anyone have an idea of what it can be?? im thinking catalytic. before the test i replaced spark plugs, cap and rotor, cleaned fuel distributor, cleaned IVC, ran seafoam 2 tanks before test(did not test with seafoam in fuel). fixed vacumme leak i had at IVC hose(ran alot better after the fix)used vacumme to see if any other leaks where present and there was nothing. i had the timing retarted for the test. let me know your thoughts thanks.
Old 04-06-2011, 07:51 AM
CRAZY_RUSSIAN's Avatar
what fuel are you using? you need low octane! you can also use SF in your block.
it could be the cat..
Old 04-06-2011, 09:03 AM
vwdt2008's Avatar
i didnt metion it was a 1988 90 2.3l 10v. im using 87 octane. i did an oil change too, my crank case hose is collapsed could that cause a problem????
Old 04-06-2011, 11:49 AM
Loudgoldwing's Avatar
If, by "Crankcase Hose," you are referring to the 3" diameter air intake, absolutely YES that is your problem. If that's collapsed, not enough air gets to the engine, causing you to run rich.
Old 04-06-2011, 12:01 PM
Hybrid_Hatch's Avatar
Add a couple gallons of e85 to your tank, you'll pass with flying colors.
Old 04-06-2011, 02:41 PM
vwdt2008's Avatar
no not the intake boot. the hose off the oil crank case that runs to the intake boot.
Old 04-06-2011, 03:11 PM
no not the intake boot. the hose off the oil crank case that runs to the intake boot...
It's the same difference. You're suffering a combination of both a major vacuum leak AND an unmetered intake air leak.
As for E85, IMHO that stuff burns WAY too fast and is WAY too caustic for our ignition systems. You'll give the sensors fits, and likely set the "CEL" a-burnin' bright.
Old 04-06-2011, 03:31 PM
vwdt2008's Avatar
but the hose isnt broken its just gone soft and collapsed.
Old 04-06-2011, 03:34 PM
Replace IT!
whats E85? :-?
Old 04-06-2011, 04:02 PM
vwdt2008's Avatar
Originally Posted by CRAZY_RUSSIAN
Replace IT!
whats E85? :-?
would the collapsed hose cause a problem with the test??
e85 is 85% ethanol and 15% gasoline.
Quick Reply: Here are my emissions test FAIL results!!! Your advice needed...
