heres the engine code thanks for checking for me scargo02
<center><img src="http://pictureposter.audiworld.com/32880/enginecodesticker.jpg"></center><p>if i read it right its 6538 but not sure about the 21 or the even lower 1..?
...that being said that engine would be from a 1993 production car - in between 09/30/92 (# AAH 176 589) and 10/31/92 (# AAH 185 689).
All the engines that came into the US started around # 079 185 (for '92 100s) so the 4 digit number couldn't be the engine code - plus it's usually right after the engine code (ie. AAH 177 34x). Since that's only a sticker though, I'd check to see the actually stamping on the engine block...
Either way it's still a really 12V - I'd for sure replace all the gaskets, check valves, etc.
<IMG SRC="http://audi.mtnre.com/public/AAH_engine_code.gif">
<B>The engine code letters and serial number are stamped on the right-hand side of the engine cylinder block, between the cylinder head and the power steering pump.
In addition, an adhesive label on the drive belt cover lists the engine code and engine number (serial number).
The engine code is also found on the vehicle data plate.</B>
<ul><li><a href="https://forums.audiworld.com/12v/msgs/47806.phtml">https://forums.audiworld.com/12v/msgs/47806.phtml</a</li></ul>
Kingate
01-19-2004 12:32 PM
