How to check if fan control switch works or not, bentley doesn't really say how...
My car was running pretty hot lately so i changed my coolant yesterday, it was black!, and then i just realized my fans won't come on unless AC is on. Would that be FC switch or s'thing else?
TIA
TIA
short-circuit the plug and look if the fan starts, if not, your fan is dead
if so, the sensor (left/bottom radiator side) is bad.
and btw, try to change your coolant before it comes black!!!!!
is a on/off sensor that gives the signal to the fan to go on or off......
it has nothing to do with your 2 guages in the car, this one is only an on/off sensor.
If I'm not mistaken, 5k's, 90's, 80's and 4k's have the same sensor so if you got a friend or have another Audi, interchange them ( you will loose some coolant but if your're fast, you won't loose alot)
and it's on the driver side, look under the car on the driver side and you will see a sensor that goes in the rad with a 3 pin plug
Coolant black.
Was the coolant black in the expansion tank as well or just when you drained the stuff? Eek!
I'd let whatever you put in the cooling system run for a week or two and flush out the system again to get rid of contaminants.
Steve_Ag Arrow
01-08-2008 03:54 PM
AudiS4guy - NorCal
10
02-11-2005 12:11 PM
ScarfaceNostra
08-25-2004 09:19 AM
