how do I remove the interior door panel of my '93 90S front driver's door?
<center><img src="http://pictureposter.audiworld.com/6607/doorpnl.jpg"></center><p>The door panel has hidden screws everywhere!
Front door trim panel, removing and installing
1 - Sheet-metal screw
2 - Filler piece
3 - Lock **** To remove, turn approx. 180 to left and pull off
Installing: push down and turn approx. 180 to right. Lock **** should project 16 mm (5/8 in.) above guide ring
4 - Inside door release mechanism. Remove hidden screw beind handle. Push in direction of arrow and pull out of trim panel. Disconnect cable.
5 - Height adjustment clip
6 - Trim plate Removal not necessary to remove door trim panel
7 - Packing for retaining hooks Pressed on
Lightly bond for easier mounting
8 - Insulation
Attached to door trim panel with clips
9 - Front filler piece (installed)
Pull filler piece from frame Fig. 3
10 - Door trim panel Number and location of retaining tabs
11 - Gasket
12 - Phillips-head screw
13 - Armrest (lower part) When installing, locking tab must fit into cutout in upper part
14 - Phillips-head screw (2x) For mounting door trim panel and armrest (upper part)
15 - Armrest (upper part)
Lift out and disconnect harness connectors for power window regulator and mirror adjusting mechanism
2 - Filler piece
8 - Insulation
11 - Gasket
<center><img src="http://pictureposter.audiworld.com/6607/doorlock.jpg"></center><p>Slightly difficult to get to. However the inner door fram can be removed if needed
FASTAXI
9
02-17-2009 07:01 PM
BoostFrenzy
09-11-2007 04:21 PM
slimcubby
06-11-2005 07:45 PM
Mark - Steve's bro'
Audi 100 / A6 (C4 Platform)
9
11-24-2003 05:53 AM
