How to enter lockout code on radio?
My radio is locked out (i think, it says safe on it) and I need to know how to put the code (which was on a sticker on the rear triangle window) to enable it? If i'm thinking completely wrong here, let me know, but when i turbn the radio on it says save, and if i turn it ALL the way up i can faintly hear the radio and no buttons work...
Press and hold FM and AM at the same time....you will then get 0000 on a radio....use 1,2,3,4 numbers to enter your code and then press and hold FM - AM again.
The radio code is located on a sticker in the separate radio manual which should hopefully be in the glovebox along with the manual and warranty information. The radio manual also has the instructions for entering the code. If you no longer have the manual you're stuck going to the dealer.
furiousgeorge
17
09-01-2006 10:34 AM
