how exactly do I open up my door if it won't open...
Something with the latch messed up cause I can't open it from the inside or the outside. And I may be able to fix it if I could take off the paneling, but it won't come off with the door closed...
I'm supposed to do what now?
i hope u have all the skrews taken out of the door still..if not o boy i dont know what u can do but if u do just pull up as hard and u friken can from the inside and it will iventually come up! i was stuck inside my car when it wouldnt open! hope this helps??
I know this sounds really easy but...same thing happened to me after I put leather door panels on I couldnt get the passenger to open all the time. One night it wouldn't open from inside or out. I finally opened the window and stood outside. Simultaneously grab the pin and pull up hard while lifting the lever. Mine still does it every now and then. Hope you get it sourced.
GIAudi
02-25-2009 05:42 PM
StealthB4
11-25-2005 08:53 PM
mdwsta4â„¢uroslut
07-27-2002 05:45 PM
