How involved is replacing the serp belt on a B4 90? i.e. what needs to be removed?
Re: How involved is replacing the serp belt on a B4 90? i.e. what needs to be removed?
10mm hex socket in the tensioner rotate it clockwise until you can put a skinny bolt through the two "eyes" that line up change the belt and then rotate it slightly clockwise and pull the bolt out and let the tensioner rotate back. I think you may be able to pull on the belt hard to rotate the tensioner but I would use the socket and the socket wrench.
Jim Bush
Holland, MI
Jim Bush
Holland, MI
The front plastic engine cover of coarse. Four allen screws, two under the top engine cover and two
on the front. I don't have a B4 but I know for sure that cover has to come off in the least.
i was going to say, " is this a serious question???" on your behalf...
but since i guess you are only a B3 and C4 person i guess it is... yea its VERY easy to do take off the cowl on the front with the two allen heads and then pull it up and use i think a 17mm on the tensioner to relieve it and the belt comes right off. there is a special "bold head" on the tensioner to put the 17mm on too
shadyraven
9
03-07-2024 09:42 AM
Scenic Driver
9
08-26-2006 09:18 PM
wakizaspeed
11-12-2005 05:15 PM
UrS4boy
Audi Original "S" Cars
02-24-2004 09:57 AM
